How can I run a DAQ program on windows 2000 at startup but before login and have it show up in the taskbar after login?
I need a DAQ program to start running at startup but before login in case someone is not there to login. I tried the task scheduler but when I log in the program is running in the background and I cannot interact with it.
(2,738 Views)
I would suggest making your program a service in Windows 2000. Microsoft sells the WIndows 2000 Resource kit which has some utilities to convert any executable to a service. I think there are some shareware utilities as well. Then, make sure your service has a taskbar interface (a cute little icon in the taskbar next to the clock). This may have to be done with some external programming, but I am not sure on this. You will also need to make sure that the NI-DAQ service starts before your service. I think this can be done with some registry edits.
If you get this finished and working well, please post back how you did it so that we can share this knowledge with other users of LabVIEW.
Randy Hoskin
Applications Engineer
http://www.ni.com/ask
(2,738 Views)
