How can I sample from a soundcards output?
I´m having a software which sends audio stream to the soundcards output so I can hear the sound.
How can I sample this sound in to Labview?
I´m a rookie to Labview and should apprechiate a .vi file as example.
Thank you!
Mark
(2,703 Views)
Hi Mark,
there are specific modules for sampling sound for example the USB-9233. There are also examples in the example finder in LV. Take a look at the "Continous Sound Input.vi" for example. There you connect a microphone to the soundcard and sample it that way.
I hope this helps you.
Good Luck and welcome if you have more questions.
Andreas E
(2,660 Views)
