How can I save the front panel information for later retrieval?
I have a front panel that get populated with information (arrays,indicators,strings,nemeric, etc.) throughout a test sequence. When the test is finished, and before the next one runs, I would like to "capture" this information and store it, and then later reproduce this information in it's same format. What is the best way for doing this?
Thanks!
(3,462 Views)
VI server, there also was an article on zone.ni.com about how to do it.
kanders
"sal" wrote in message
news:101-50650000000800000072150000-982303670000@quiq.com...
> this?
> Thanks!
(3,462 Views)
I second that initial response, but here's some more help if you can't find the info on Developer Zone.
One article on this topic can be found at the following URL:
http://zone.ni.com/devzone/conceptd.nsf/webmain/1C98B128C80E52BE8625692E0055D456?OpenDocument
That first one wasn't coming up in the search. You can also Search for "labview current values default" and you should find an example program that demonstrates some of the topics using VI server.
John Lum
(3,462 Views)
You may also want to check out the "log at completion" option under the operation menu and the rest of the data logging operations.
Stu
(3,462 Views)
Sal,
There are number of examples on different aspects of what you are reffering to, using VI Server in the Resource Library of NI Develpoer Zone: http://zone.ni.com/libraries/
If you go to LabVIEW -> Connectvity -> VI Server you should find a couple of useful examples including:
1) Get/Set control values using VI Server
2) Making Current Values Default with VI Server
Kamran
An
(3,462 Views)
Hi all
It seems the best solution for saving last changes of a front panel controls and indicators value when a VI is going to close is checking "Log at completion" and giving Log file path. But there are not any option to load VI with the last record number automatically, and you should choose record number manually by clicking Operate>> Data Logging>> Retrieve and choosing last record number !!!!
I need an option which a front panel loads with last record number automatically or by programming. I had a look in properties and methods of VI Server Refrence but did not find anything. "Automatically Retrieving without clicking any menu"
(2,850 Views)
