Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I see certain CIN source file?Now I only saw the node,but found not corresponding C file?
Lab
Member
06-24-2003
07:25 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Why??I hope I can see it,Can I?
0
Kudos
Message
1
of 2
(2,585 Views)
Reply
Re: How can I see certain CIN source file?Now I only saw the node,but found not corresponding C file?
Dennis_Knutson
Knight of NI
06-24-2003
08:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
No, you can't see the C source code unless the developer of the CIN gave it to you. Once a person has created the .lsb object file and loaded it, the source code does not have to be present. Same thing as a DLL.
0
Kudos
Message
2
of 2
(2,585 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
