How can I see certain CIN source file?Now I only saw the node,but found not corresponding C file?
Why??I hope I can see it,Can I?
(2,579 Views)
No, you can't see the C source code unless the developer of the CIN gave it to you. Once a person has created the .lsb object file and loaded it, the source code does not have to be present. Same thing as a DLL.
(2,579 Views)
