How can I send one analog output from USB-6002?
Hello, I am now using LabVIEW 2013 and DAQmx9.9 with USB-6002.
I want to send analog voltage from AO0 and AO1 at the timing of trigger on PFI0
I have used DAQmx write (N channels, 1 sample)
because I want to send one voltage for each channel.
But the program just stops saying that buffer size should be set as 2 or larger.
Even if I use DAQmx write (N channels, N samples), it still does not work
showing the same error. It works if I give 2 or more samples.
I want to send out analog voltage at the timing of trigger coming on PFI0
with almost 5kHz rate, so I do not want to send out two same voltages
including one dumy data.
Thanks in advance for your kind advice.
Message 1 of 9
(5,837 Views)
Have you tried having a look through the built in example finder in LabVIEW for something similar?
There are loads of examples online but is it something like this you're trying to achieve?
https://decibel.ni.com/content/docs/DOC-25374
Message 2 of 9
(5,764 Views)
You failed to attach your code, so I cannot see what mistake you made, but from your comments, I'm guessing that you wired a single value to the DAQmx Write.  Note that if you set it up for N Channels, 1 Sample, that corresponds to a 1D array to hold the N samples.  If you want to send N Channels, N Samples, you need a 2D N by M array (I leave as an "exercise for the reader" to figure out if N is number of samples or number of channels ...).
Bob Schor
Message 3 of 9
(5,752 Views)
Here I attach a code which I have used. (AO-single.vi)
I made this VI simplifying a VI example included in LabVIEW 2013.
Here is an error shown by this VI (in Japanese version).
So, I have translated meaning in the following.
The error message (error code-200077) says that SampQuant.SampPerChan
was set as 1 but it should be 2 or larger.
I guess that internal code of DAQmxTiming(Sampling Clock) requires
sample per channel to be 2 or larger. But this requirement conflicts
with usage of DAQmx Write (N channels, 1sample).
Message 4 of 9
(5,702 Views)
Hi yab,
I want to send out analog voltage at the timing of trigger coming on PFI0 with almost 5kHz rate, so I do not want to send out two same voltages including one dumy data.
What's the sense in defining a sample rate of 5kHz when you output just one (1) sample? You either output that sample or you don't - there is no reason to define a dt for outputting the next/2nd sample…
1) That beeing said: why don't you output 2 samples per channel? You might even output the very same value twice - it is a very simple solution I think.
2) What happens when you don't define a sample rate?
(What's the sense of using "N channel" mode at DAQmxWrite when your task only contains one (1) channel?)
Message 5 of 9
(5,694 Views)
Thank you for kind comments.
1)
It works if I send 2 samples per channel sending same voltage.
But in this case, it takes 1/5k*2=0.4[ms] for each operation.
I want to send different voltage at every 0.2[ms], so I cannot use this solution.
2)
As you say, It might be nonsence to set frequency when I send out one analog output.
The result may not be dependent on the sampling frequency if it works.
If DAQmxWrite can run without using DAQmxTiming, it may solve the problem.
But VI shows an error if DAQmxWrite is used without DAQmxTiming.
The devise is now in use, so I will check the error code later.
Message 6 of 9
(5,689 Views)
I think you need to either:
1) Remove the timing block altogether - you are configuring the timing to use hardware timing but if you only specify one point of data for each channel, it does not have any further points to 'time'
2) Set the timing configuration to 'implicit' - I believe this will have the same effect as the above but I might be wrong.
3) Make it a 2D array with N Channel M Samples for the DAQmx write
(blog)
Message 7 of 9
(5,679 Views)
Thank you for your advise.
1) If I remove DAQmxTiming, it shows the following error.
2) If I use implicit, an error comes out shown below. It may be because I have used DAQmxWrite with implicit setting for counter (not for analog output).
3) I have used N channels M samples sending 2D array, but the results (errors) are all same.
Message 8 of 9
(5,661 Views)
Here is the error when I use DAQmxWrite without DAQmxTiming.
It seems that digital trigger requires to set sample clock (DAQmxTiming)
even though I do not know why there is such a requirement.
DAQmxTiming should set sample per channels to be 2 or larger
and this requirement sounds reasonable to make definition of timing (between samples).
Anyway, from above requirements, it is impossible to send 1 sample at each digital trigger.
Message 9 of 9
(5,658 Views)
