How can I set a deadband for PID control
when I use a PID.Vi to adjust a pressure, when the PV close to SV, I want the PID.vi hold its output,but I have no idea to set the deadband parameters! (can not find how to set dead band )
A PLC engineer said that   deadband is a common PID  parameters ,but Idon't know how to set it in labview pid !
Help ,please,thanks!
(10,062 Views)
Accepted by yyoung
You already wrote what you have to do. One possible implementation is simply "freezing" the output of the PID controller. Use the "advanced" version of the PID VIs (either the normal or the one with autotuning if you need it).
(10,032 Views)
Thank you very much! It works well
(9,992 Views)
