How can I set an event structure up so that it only recognizes a boolean value change from false to true?
I am attempting to design a program with multiple buttons that displays the time elapsed since the program began that the button was pressed. I need the buttons to be set so that they switch until released however I only want it to register the initial button press (from false to true), not when it returns back to false. I have attached a sample of what I am working with thus far.
(4,621 Views)
Boolean Crossing Pt by Pt
But since you are using an event structure, pick a mechanical action that works with it.  Try Latch When Released instead of Switch Until Released.
(4,618 Views)
If you have to have the Switch Until Released action, put a case structure in the Value Change event, wire it up to the New Value node and do nothing in the False case.
aputman
(4,600 Views)
Try to Explore More about Implies function and use the Event structre values of New and Old values and decide the Transition as True to false or False to true as you wish.and decide the case inside the event
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,566 Views)
