extract pattern match image
Dear all,
I'm doing image processing using labview
Getting image, I perform geometric mathcing, set coordinate system(on the matched geomatry) and shape detection.
Here, I wanna extract positions of matched patterns based on the set coordinate system. and save it to a new image can i do that?
i tried imaq extract but could not get my request
I;m very appriciated for your help in advance.
(3,850 Views)
Accepted by topic author zainabmaghraby
@zainabmaghraby wrote:
Dear all,
Use IMAQ Extract 2 to extract the Image with Specified Co Ordinates and then IMAQ Write to file for writing into File(You can select the image pattern bmp or png)
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,797 Views)
if u want use the extarcted image as am template then use IMAQ learn colur pattern tools before writing into file
(3,795 Views)
