How can I set the frequency range via USB without losing the Network Monitor?
Hi, I have the Network Analyzer Rohde Schwarz ZVB 8.
My goal is to set the frequency range via PC and seeing the change on the Network Monitor. I implemented this simple VI:
The problem is that, after the running, I lose the Network Monitor and I cannot see if there was a change. I want, instead, to see the change on the Network monitor.
Can you give me an advise?
Thanks in advance.
< The Quiter You Become, The More You Are Able To Hear >
(2,377 Views)
Ciao Luana,
non ho ben capito cosa vuoi fare, da quello che si vede il tuo VI parte, setta la frequenza e poi si chiude.
Hai inserito un while loop prima di chiudere il task?
Valerio
(2,306 Views)
