How can I stop (freezing) the scope screen Tek MDO 4054C using labview
@ZhouRay200 wrote:
Thanks for your advice, the problem is solved, but not by using a trigger which can't wake up the scope.
Good to hear, but please do tell us what you found just in case someone has the same problem later.
 wrote:
Problem is solved. The flat sequence structure just for making each part looks clean when I try to design a new code.
 Superfluous.
=== Engineer Ambiguously ===
Message 11 of 13
(572 Views)
I used a super inconvenient way to run the scope again which is reset everything again with the auto set VI. All other ways I tried only to wake up the scope to the single mode.
Message 12 of 13
(567 Views)
Actually, I like that idea - makes it ready for the next person to use.  This should not be used to reset the o-scope between measurements, though, but only after you are done with the scope.
Bill
CLD
(Mid-Level minion.)
Message 13 of 13
(562 Views)
