How can I test for the bas unit enterd in a control?
How can I to create a polymorphic vi where the user can enter either volume or temperature.
how can Labwiev test for the base unit entered
pseudocode example:
input X
if X.base_unit == m^3 do .......
thanks for any suggestion to resolve or avoid my problem
(3,884 Views)
The LabVIEW Help indicates how to deal with Polymorphic Units.
(3,868 Views)
I know this help page, but it doesen't seem to apply to my problem. I don't want to to the same thing for different units, but LV has to branch depending on the unit the user did enter.
(3,860 Views)
Accepted by topic author schaerm
Hi schaerm,
you have to dig deeper.
An idea is this one:
The red marked word is containing the unit - in a coded way. Somewhere in the LV help you can find the description of this coding (I remember a chapter on memory representations of all LV datatypes...). (There surely is an easier or better way - but the example is done quic&dirty.)
You can also format the number into a string and analyze the unit here...
Message Edited by GerdW on 02-07-2010 07:21 PM
(3,854 Views)
Thank you GerdW!
The variant solution works perfect!
(LV does not allow to format a number with unit to a string)
Best regards Mark
(3,844 Views)
Hi schaerm,
"(LV does not allow to format a number with unit to a string)"
Ofcourse it does!
(using a simple FormatIntoString...)
(3,841 Views)
Sorry, I was testing the the wrong functions (number2nstring)
just getting tired
Best regards Mark
(3,835 Views)
