How can I transmit and receive messages using Vector CANTech CancardXL with LabVIEW?
I'm a new LabVIEW user and I need transmit and receive CAN messages using a CancardXL from Vector CANTech with LabVIEW.
Could somebody have any vi or suggestion?
(3,788 Views)
I made a set a LabVIEW VIs to work with Vector/Softing CANCards starting from an example program I downloaded from Softing. These use the Call Library Node to interface with the cards .dll.
I can't give these out because they were developed for a customer. I would contact Vector and see if they have an example program for your card. Might be the same one I started with.
[caution, salesman hat going]
Of course if you need help developing the VIs, we'd more than happy to assist you.
[remove saleman hat]
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,776 Views)
Have you work with the hardware CanCardXL and using the CanOPen Library? Is there a VI available?
(3,415 Views)
