How can I unlock a front panel/block diagram in LabVIEW 7.1?
I inherited LabVIEW (7.1) code  that when I try to edit, I am not allowed. I can access and used Functions and Controls, but I cannot connect or delete them back. The mouse indicator is a hand all the time. It does not change to cross hair or wiring tool.
In the  Security section of VI properties "Unlocked(no password)" is selected.
How  can I fix the problem?
Thanks for your help.
(4,105 Views)
Try Operate>>Change to Edit Mode (Ctrl+M).
___________________
Try to take over the world!
(4,097 Views)
Sounds like you have got the automatic tool shutoff, go to menu and select window/ tools pallette and then turn back on the automatic tool. I think this is where it is located for 7.1.
Joe.
"NOTHING IS EVER EASY"
(4,096 Views)
