LabVIEW with Wibu Key
I have searched this forum and have found the Wibu-Key method of Software Protection mentioned, but no one seems to have mentioned any actual Interface Method / Examples of HOW to tie it into LabVIEW.
So far, Wibu Systems does not have any examples of interfacing with LabVIEW.
Can anyone that has used the Wibu-Key with LabVIEW provide me with some suggestions or examples??
(3,748 Views)
slbLV,
Personally I have not used Wibu, but from the posts from waldemar.hersacher it seems that the Wibu implementation that he was speaking of was for C based programs.  There are quite a few good posts about copy protection in LabVIEW though if you search for that.  Here is one that I came across.
Application Copy Protection
Hope this helps!
Andy F.
(3,709 Views)
Andy F,
Thanks for the thought... I have searched "copy protection", etc. also, and have read this and 5 other posts that had Wibu-Key mentioned, plus several more that did not.
I've determined that the 'external hardware' seems to offer the best solution for our situation, but need to get the Wibu-LabVIEW interface going.
I know I need the COM interface within LabVIEW to do it, but this is totally new to me. I am trying to work through the Wibu Manuals and the COM use in LabVIEW, but if someone had already done this and could provide some experienced insight, it would really be a time saver.  Thanks.
(3,705 Views)
The best advice I can give would be to keep at it and post if you have any specific questions!  I also might post on one of the other Wibu threads and see if you can get any advice there as well.
Good luck!
Andy F.
(3,675 Views)
