How can I use Agilent B2902A in mode AMPS
Please i want to supply a board with I=0.930mA and U=15V.
Can I change the exemple delivred "Agilent B2900 Series Output DC Volts.vi" from mode voltage to mode amps.
Cordially.
(2,766 Views)
Cordially.
Not sure what you are trying to do.  You can either control current or voltage, but not both at the same time.  You can control voltage and let the current be what it wants to be (the most common mode), or you can control current and let the voltage be what it wants to be.
I think you have a basic misunderstanding of "power requirements and/or specifications".  From what you stated above, I am assuming whatever you are supplying power to needs 15 V and will draw 0.930 mA (which I don't believe - did you mean 0.930 Amps?).
In that case, just supply the voltage and monitor the current.
Bill
CLD
(Mid-Level minion.)
(2,728 Views)
Thank PROVEN ZEALOT for your reponse,
I found a solution for that but i still have a probleme in measurement, the values in display of the Agilent B2902A,
  • Either I get the same current display and an almost similar voltage value
  • Either I get the same voltage display and a value almost similar in current
I do not know how I can have both measurements displayed on the LCD.
Cordially.
(2,461 Views)
