converting sql to udl file
how to convert .sql  file to .udl file.
for using the database connection toolkit.
as the input for dbct is connection information which should be a .udl file.
please help me.
thanks...
(4,038 Views)
A .udl file is used for storing connection information.  A .sql file is typically SQL code or queries that you wish to save to disk.  Both are text files but are not really used in the same manner.  So I don't fully understand your question.
You can create a file on the desktop with a udl extension, double click the file and use the Data Link Properties box to establish a connection.  Then you can open the udl file with a text editor to grab the connection string.  Maybe this is useful for you.  If not, please explain your question.
aputman
(3,973 Views)
ok thanks...
I got another error
please try to solve it.
(3,744 Views)
Accepted by topic author charan6066
You are using the wrong driver to connect to the database. Did you use the UDL file and data link dialog box to test the connection?
aputman
(3,636 Views)
thanks for helping me.
now I used the correct driver to connect the database.
(3,611 Views)
