How can I use USB RAW device in Interrupt data transfer write mode?
When using a USB RAW device, I know that I can read in Interrupt Data after a USB interrupt has occurred by using the "Get Interrupt Data.vi", but how do I write out an Interrupt pipe to my device from LabVIEW using VISA?
(4,473 Views)
(4,469 Views)
Thank you for your reply. But I can not connect the property node which you suggest me in reply of my question because there is problem of connection. Here I am attaching my vi so can you please give me the solution of my question, How can I use USB RAW device in Interrupt transfer write mode??
(4,430 Views)
Refer to the attachment. Do that once, it should work.
Vaibhav.
(4,152 Views)
