How can I use prompt user for i/p with password display?
I am trying to use "Prompt User for Input" express vi to get password from the user, am able to add a text box entry, but dont know how to make it as "Password display".
Can any one help me out on this?
Kousy
(3,485 Views)
Hi Kousy
With the standard express vi you can't do this. So here are the steps how you can do it:
1. Place the express vi on the block diagram and configure it as needed
2. Right-click it and select "open front panel"
3. In the following dialog select convert -> now it is a normal sub-vi
4. Right-click the string-control and select "Password display"
5. Save the vi
Now it should work.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,480 Views)
