How can I write scalar data into XL report genration vi?
I'm making few measurements and would like to write this scalar value in excel. It seems that all Vi uses 2D array. I've used XL "append table to report" related vis. I can not provide 2D arrays in each case. How can write "DBL" to XL?
(2,690 Views)
If you look a little deeper into the shipping example called Write Table TO XL, you'll see a subVI called Set Cell Value. This is inside a for loop which is how a 2D array gets written. Use the subVI by itself to update a specific cell.
(2,690 Views)
