How can i bundle the variables in this VI?
I need bundle time and time , with each temperature measurement..i used clusters, but they are showing broken arrows all the time..
Thanks for any help..
(3,310 Views)
I got the bundling thing..plz see whether its right or not?? Also, the time stamp, doesn't updates the time...is there anyway, the time stamp update the time as the Vi is run.
(3,305 Views)
hi bunny,
try to use the "build waveform.vi"
have a look at the "create waveform example.vi" shipped with labview
regards
tiimo
(3,304 Views)
Thanks for the advise, but do ihave to use thw build waveform.vi?? I just want to bundle the temp. measurement, time & date of measurement...also, i need to set up time delay so that is executes 4 times in a sec....
wat i have done needs some modifications? can you tell me is that write or not??
(3,301 Views)
Try the vi which i have attaching. Let me know whether my vi is suitable for your application
(3,298 Views)
Thanks,this just works fine....thanks a lot.
(3,289 Views)
