How to change the background color of a XY-Graph from black to white
(10,465 Views)
hi Christian,
It depends whether it needs to be done during run-time or programming.
If you only need to customize your control, use the "set color" tool from the tools palette.
If you want to change color while running the vi, use the property node "plot area>colors>BG color"
(10,462 Views)
