How can i convert int16 to float32 (MSW-LSW) ?
Can someone please tell me how to convert int16 to float 32 (MSW-LSW)?
Kind regards,
Balázs
Message 1 of 9
(6,259 Views)
Not sure exactly what you are after here. Did the To SGL not do what you want?  If not, do you have an example to help us understand your issue?
GCentral
Message 2 of 9
(6,247 Views)
I use the following tool for scanning modbus TCP as reference. I would like to find out how to get 61.06516 which is a float32 (MSW-LSW)
Here is my code:
My "Output" is 17096. I reckon this number is the one that should be somehow transformed to 61.06516. Am i right or wrong?
Message 3 of 9
(6,223 Views)
And this is why examples are so important.
Your problem is you need to use 2 words to combine to make your 32-bit value.  Use Array Subset to get words 5 and 6 (index 4 and 5).  Then you can just use Type Cast to convert to a SGL value.
GCentral
Message 4 of 9
(6,214 Views)
I get 1,39232E+12 as output when MSB=17012, LSB=17096.
Is there something that i am doing wrong?
Message 5 of 9
(6,141 Views)
Accepted by LTBALAZS
You want SGL, not DBL (DBL is eight bytes) change the representation of all your orange elements to SGL. (indicator, diagram constant wired to the top of typecast, NAN in the other case)
You cannot turn four bytes into eight.
Where did you find this VI?
Message 6 of 9
(6,132 Views)
I created a numeric indicator then changed its data type to SGL, and the data type of "Casted Number" to SGL (right click -> properties -> data type..)
I found that vi here:
https://forums.ni.com/t5/Example-Code/Cast-Two-I16-Numbers-into-One-Double-Precision-Number-Using/ta...
Thanks for your help!
Balázs
Message 7 of 9
(6,114 Views)
Here is a pro tip that was not done in the link you provided, nor on CrossRulz's example above.
Make the label visible on that typecast constant and edit it to say SGL.  That documents that the intention is to typecast the input to a Single, and not one of the other 5 data types that are also floating points with an orange color.
Message 8 of 9
(6,092 Views)
That is exactly what I do for constants where it is important to know the data type.
Bill
CLD
(Mid-Level minion.)
Message 9 of 9
(6,044 Views)
