How can i create trigger on JAI CM040MCL camera?
Hello
i need help
i have JAI CM040MCL camera and daq (6009) and i want create trigger for camera, how can i do it?
for example , i want that everytime that i send 5v to Ai0 (one of daq digital output)  the camera take photo
* i know that PIN 10 responsible for camera trigger (attached image)
thanks
(2,726 Views)
Hi ArieGaon,
You should be able to generate a digital pulse using the 6009 and send that to the camera's trigger input. Most camera manufacturers allow you to select from different triggering options. You will need to choose the best one for your application. There are plenty of examples for generating digital pulses using DAQmx that should allow you to do this. Here is one that may work for you:
Digital - SW-Timed Output
https://decibel.ni.com/content/docs/DOC-25288
(2,694 Views)
