Plotting coordinates
Im trying to make a program that will plot coordiantes on a graph using the click on a mouse then connect up the points. Any ideas on where i would start? ive seen a few ideas on the forums but im not sure on why some of the parts are there and i dont want it to be very complicated
(2,518 Views)
This would be an excellent starting point that you could modify for your application.  Save last mouse down and use it to connect a line to your current mouse down.
Matt
http://www.ni.com/example/27021/en/
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,508 Views)
