How can i fill a ROI with color and save it ?
Just FYI, IMAQ wires contain a reference to an image not the image data, so shift registers would be useless.
As for ROIs, the ROI cluster consists of a global rectangle and an array of contours.  What you need to do is use the function IMAQ Group ROIs to turn an array of ROIs, each with a single contour, into a single ROI with several contours.  Then you will see all of them.
Message Edited by rpursley8 on 03-14-2008 09:46 AM
Randall Pursley
Message 11 of 11
(592 Views)
