How can i make 2 functions happen sequentially in a loop
Hello, i have a problem with this VI. I want to make the 2 subVIs happen one after another in the while loop: when the first one has finished the second one starts, and when it ends the loop starts again. I tried to come up with a solution with a case structure, making the second subVI as a condition for the result of the first one, but it doesnt really work: the second subVI only runs for a couple of seconds when the condition is respected, but since the first subVI runs from start , it stops running after a seconds. What could i do to make the two VIs run sequentially as i said?
Thank you
Message 1 of 9
(2,466 Views)
Accepted by topic author domcorrado
If your VIs have error cluster terminals wire them to set the order you want. If not, you can use a Flat Sequence Structure.
Lucian
CLA
Message 2 of 9
(2,454 Views)
In that case you should rather make those subVIs to use errorIO to enable simple DATAFLOW…
Message 3 of 9
(2,446 Views)
Yes, if you can edit those subVIs.
Lucian
CLA
Message 4 of 9
(2,439 Views)
I managed to do it with a flat sequence, gonna also try with the error i/o dataflow and see what fits my case more.
My only problem now is that i have all of this in a while loop to make it run repeatedly, but it just doesnt happen (only runs one time), any idea why?
Message 5 of 9
(2,423 Views)
Hi
I think the problem is, that the second loop has a false constant wired to its stop condition. It runs endlessly.
If you make it a true constant it should work.
Message 6 of 9
(2,406 Views)
problem is, if i make it a true constant, the first subVI will start running again instantly, during the time the second subVI still runs, which i dont want to
Message 7 of 9
(2,394 Views)
No, this is not true! VIs are executed one after the other. Use Highlight Execution to see better what's happening:
Lucian
CLA
Message 8 of 9
(2,387 Views)
Having now seen your code I would suggest that you learn about state machines. With a state machine architecture you can accomplish this task with a single loop - no need for getting stuck inside of inner loops or finding ways to program around that. I've attached what that could look like with your example.
Message 9 of 9
(2,377 Views)
