How can i make FFT array?
Hi, I want to FFT my real-time DAQ system.
I attach my program.
I refer to below design.
My DAQ's Fs=2000Hz
Data is acquired Every 0.5ms.
But I don't know how can i collect data to 1-D array.
I haven't been learn about Labview array......... T.T
Please help me how can i do that.
(3,190 Views)
You get one point at a time and the fft of that is not interesting. (I don't think you understand the typecast function).
Accumulate your values in a shift register or use "fft ptbypt".
(3,171 Views)
@Sangkyu wrote:
My DAQ's Fs=2000Hz
At the beginning of this Forum, there are links to Tutorials on learning the basics of LabVIEW.  Loops and Arrays are covered very early.  You need to spend a little time (a few hours) learning LabVIEW (would you attempt to perform an FFT using C++, or Matlab, or any other Programming Language without knowing about Arrays, Loops, etc.?).  You can also find video tutorials on the Web.  Spend some time learning.
Bob Schor
(3,147 Views)
I also think you should spend some time to learn about LabVIEW and data acquisition.
Here are some links for you.
Tutorial: Arrays and Clusters
https://www.ni.com/en/support/documentation/supplemental/08/labview-arrays-and-clusters-explained.ht...
LabVIEW / Array / Shift register
https://www.youtube.com/watch?v=IyO-OyOCh8k
FFT Example From Single Input Data Using LabVIEW
https://forums.ni.com/t5/Example-Programs/FFT-Example-From-Single-Input-Data-Using-LabVIEW/ta-p/3526...
(3,122 Views)
