How can i plot data from 2d array one at the time on the same waveform graph
Sorry sir for taking that much time to answer. but i give ur code some deeper thought and i understand it now.
thank you for the helps.Smiley Happy
Message 21 of 23
(991 Views)
You still have the wrong post marked as solution. Typically you would mark the most helpful answer, not your own post, as you did above. You can easily change that.
Message 22 of 23
(973 Views)
good day Altenbach.
i still need to thank you for you input in my last post since from there i was able to take my task further and it help me understand labview arrays more deeply. i am sorry not to havequoted your reply as the solution to my post at first, i complitely got it wrong. but here i am experincing another trouble. what i needed to have many tab in my final program. the first tab will show the data plotting as bar chart for each channel, the second tab page will show a picture of the plant which will highlight specific point and popup some message as the mouse moves and get click on the picture. i was able to that working. the problem is that, when i run the program on the page having the waveform for the channel the code there get run,when i change the page to go to the page with the picture, and move my mouse around nothing happen and if i go back to the first page the control and indicator there get frozen and i  cannot go back to the second page. i am using an event structure to handle mouse movement on the second tab.at first i thought something was wrong with te event structure.but after i use another vi with tab control putting the same code i use for the acquisiton i could see the same behavior.i mean when u change the tab code on the other tab is not executing anymore.
my explanation my not be that clear, but i have attached the vi i am actually working on.
thanks for taking a look
YannStephen
Message 23 of 23
(956 Views)
