How can i write a sign string in VISA Write?
Hello everybody.
I would like someone to help me. I have an array, which is transformed (by Byte Array to String) in a string that reaches the VISA Write Serial Port. My problem is that when making the transformation with Byte Array to String, i  lose all the bytes with sign (negative).
What can I do? I don't want to  lose the sign bytes and be able to send them to VISA Write Serial Port.
Thank you very much.
(2,685 Views)
It sounds like you have a typecasting problem.  First, why do some of your bytes have a sign?  I assume they are I8.  Strings are based on U8 because they are just a series of ASCII characters vs. values.  The ASCII character table goes from 0 to 255.
What happens on the other end of the VISA communication string?
One thing you could do is to typecast your bytes to a U8.  Though I think the coercion dot of an I8 byte array going into the byte array to string is doing this automatically.
(2,673 Views)
This was already answered in another post with the same title in spanish.You can find it here:
http://forums.ni.com/ni/board/message?board.id=6170&message.id=7257&query.id=21551#M7257
In short and going beyond of the meaning of a negative byte, you can do it with the one of the functions in the Palette of String/to Number Conversion.
Best.
(2,655 Views)
