How can you change the value of "N" (forloop) during iterations?
I am wondering how to change the value of "N" in a for loop. The thing is that, when a certain condtion is not met, the for loop needs to increment the value of "N".
The code in c++ would look like this...
for (i=0; i<=max; i++)
if (condition)
max+=1;
Is this possible with labview?
Thanking you in advance,
D.S
(3,197 Views)
No. The number of itertions of a for-loop is not changeable after it has started to execute.
If the number of itertions is unknown prior to running the loop, use a while loop.
(3,197 Views)
Thanks!
I've already implemented the while loop and it seems to working fine!
(3,197 Views)
demo wrote:
> Hello,
> if (condition)
> max+=1;
> D.S
Dont't think so; use a While loop instead.
(3,197 Views)
