How can you list several file paths?
Hi!
I'm using the "write to binary file" vi, and I need it to write a bunch of different files. Is there a way to add several paths names to it? The green wire thingy seems to only let you put one in there at the time, and I would like to not have 20 "write to binary file" vi's in my project..
Thank you!
(2,451 Views)
Accepted by topic author q-bertsuit
Provide the file paths in an array and use a loop!
Cheers
Edgar
(2,449 Views)
String array converted to path type worked.
Thanks!
(2,443 Views)
