Various sampling resolution
I am using NI PXI 5122 card to acquire signals from Thorlabs PDA36A-EC amplified detector. I want to acquire signals with various sampling resolutions - 8 bit, 10 bit up to 24 bits. How can I do that - how can I set required sampling resolution? Is there any example I could possibly use for this task?
thanks in advance,
Marcin
(3,229 Views)
How can you get a 24 bit resolution sample with a 14 bit AD converter?
(3,225 Views)
sorry, my mistake. I meant a PXI 5922 digitizer...
(3,221 Views)
When I wanted to reduce the resolution, I mask the bits out. But this particuliar device you have to be extra czreful, because the bit resolution is dependent on the sample rate. 500Ks 24 bits, 1Ms -22 bits, 5 MS 20 bits, 10 MS 18, and 15 M 16 bits.
I do not understand why you want to limit the resolution, but remember, resolution and accuracy is not the same thing.
(3,217 Views)
why do I want to limit the resolution? I prepared some algorithm and I need to try use it with various data bit resolutions. I want to do it during the acquisition process, not after data registration (I don't want to reduce the amount of data using some app). That's why I want to change the resolution. Anyone have an idea how it can be done?
(3,213 Views)
