How come when I run Test Panel there is no input?
When I run Test Panel there is no input even though I have a thermocouple hooked up to channel 0. What am I doing wrong? I have LabVIEW 5.0, Windows 98 SE, and SCB-100.
(2,687 Views)
I wonder if you have made the correct data type input.Pls let me know the details about what you have input.
Gemstone
(2,687 Views)
The input type is Thermocouple (K type).
One thing I noticed was that when I click on "Solution Wizards" in LabVIEW, the system resources are checked and then a dialog box opens that says
"There are no National Instruments data acquisition cards currently configured.
The DAQ Solution Wizard option will be disabled until a National Instruments data acquisition board is configured."
When I start my computer at one point it shows:
ISA/PNP device listing...
Card No. Device No. DMA IRQ Device Name
1 0 7,6 5 National Instruments, AT-MIO-16XE-50
1 1 5 NA National Instruments, AT-MIO-16XE-50
2 0 NA 10 National Instruments, AT-MIO-16DE-10
3 0 NA 11 Natio
nal Instruments, AT-MIO-16E-10
Is my computer recognizing the 3 cards that are installed?
(2,687 Views)
