How could I arrange control images in a report?
I appended 4 control images to a report using Append Control Image to Report. I wanted to lay two of these images in the first line and the other two in the second line. But the result of my program was one image in one line. (BTW, I did not use any New Report Line). How could I arrange control images?
(2,735 Views)
This is guessing, but could the images be wide enough that two of them won't fit on the same line?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,735 Views)
Mike is right, unless the images are too wide, the report VIs will put them next to each other on the same line.
Please find the attached example that appends two charts on the HTML report. Open the .htm file with the web browser. If you make the browser window smaller, the charts will move one below the other.
Zvezdana S.
(2,735 Views)
