How could I possibly remove the default picture in the picture control?
I've been using the picture control and a bit of code to create a zoom effect on a picture. It all works great however I get a labview picture when the Vi is first loaded. I'm trying to get a blank area instead cause it doesn't look really tidy!
I've attached a picture and my code.
Thanks for your help
(3,008 Views)
Accepted by topic author Mr B
The image is configured to be the default value of "Picture". In other words: you have to get rid of the default. You can do this by either:
a) Delete "Picture" and create it again. Disadvantage: You have to recreate all property nodes connected to this control.
b) Load an empty picture and then select "Data Operations >> Make Current Value Default".
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,002 Views)
I have a jpg or bmp.  Is there a way to place this on the front panel of a vi..programmatically??  I don't want to cut and paste.  Want to be able to chg the bmp just by chg the file name.  I eventually want to bring the vi in Teststand and chg it programmatically so I need to maybe specify the path.  The help for "Picture" is awful.
Thanks!
(2,921 Views)
