what is the use of the auxiliary pins of 6602 counter card
          I want to know about the Behavior of the auxilliary pins in 6602 counter card.
(2,409 Views)
Hi Satish,
Counter n Auxiliary Signal
You can select any PFI or RTSI, as well as many other internal signals as
the Counter
n Auxiliary (CtrnAux) signal. Much like this CtrnGate signal,the CtrnAux signal is configured in edge-detection or level-detection mode
depending on the application performed by the counter. The aux signal can
perform many different operations including starting and stopping the
counter, generating interrupts, and saving the counter contents. You can
also use this signal to control the counting direction in edge-counting
applications.
Santhosh M
(2,401 Views)
