How could I the change the cluster order in LabView 8
I have a problem I have change from the english LabView version 7.0 to the german version 8.0 and I find not the settings where i can change the cluster order.
Can help me someone where i find this adjustment for the cluster order.
Thanks for our help.
(2,735 Views)
A VI with a cluster made in LV7 and then opened in LV8 work OK on my PC.
However Copy & paste from LV7 to LV8 VI does not work.
I assume your talking about the order within a cluster.
(2,728 Views)
my problem is that I not found the adjustment "reorder Controls in Cluster" in the new LabView Version 8.
In the old version I choose the cluster and than I make a right click and I see the "reorder Controls in Cluster" function in the new version I don't find this.
(2,723 Views)
Hi
It's still the same in LV8.0. Maybe you did not have your mouse cursor at the right position. For me it seems to be a bit trickier than in LV7.0
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,720 Views)
