How could LabVIEW read the latitude and longitiude of a position from google map
i want to use labview to control a multirotor. But how could a position be read by labview from google map?
At moment i use javascript to creat a google map DOM. It could build two txt.file with latitude and longitude. Labview can read those txt.files and get the position(like the picture). But this map Dom can only be used in IE explorer, because i use ActiveXObject (JavaScript) to creat the txt. So it is possible, that this google map DOM direct be loaded by labview, like use ActiveX? Or some better way to read the Position from google map?
Thanks for any help.
(3,549 Views)
Your picture does not show.
(3,542 Views)
thanks for your reminding. this is the  picture.
(3,527 Views)
You can use .NET Nodes to interact with GMaps in LabVIEW, here there is a library that could be useful for you: http://greatmaps.codeplex.com/releases/view/20235
And a complete example: https://decibel.ni.com/content/docs/DOC-7983
(3,495 Views)
