How di I prevent an automatic computer restart after exe install?
How do I stop the msi installer from restarting the computer after installing an exe? I have built an installer package of an application using LabView Project.  When running the SetUp.exe the msi installer is automatically restarting the computer after the completion of the installation.  I have the following in the setup.ini file.
[MsiEngine]
WinNTPath=supportfiles\WindowsInstaller-KB893803-v2-x86.exe
RequiredVersion=3.0.0.0
CommandLine=/passive /norestart
I am using LabView version 8.5.
Any help would be appreciated.
BethV
(3,573 Views)
I checked the setup.ini for an installer I built for my application. Found the following entry:
[MsiEngine]
WinNTPath=supportfiles\instmsiw.exe
RequiredVersion=2.0.0.0
CommandLine=/c:"msiinst.exe /delayreboot"
I do not know the reason for the differences. Hope this helps!!
(3,565 Views)
Hi, BethV,
Run setup.exe with /? option:
setup.exe /?
Then you will see following dialog:
It seems to be option /r:n - is what you needed
best regards,
Andrey.
Message Edited by Andrey Dmitriev on 10-31-2008 06:19 PM
(3,550 Views)
