How did you convert ASCII to normal caracters?
"Hello,
I'm new to LabView and I make a program that recived (read) caracters in ASCII from serial port and I need to convert this caracters in ASCII to normal caracters.How I do that?
Thanks.
(2,740 Views)
Use the "Byte Array To String" function. It is located in String --> String/Array/Path Conversion on the function palette.
(2,740 Views)
