Use of Audio In on laptop for Data Acquisition
I'd like to use the Audio In on a laptop to acquire 500 point per second data in a biomed experiment. Where to I get a driver or whatever code I can use to access the audio in on my laptop (a HP). I'm using Labview for windows.
(2,873 Views)
If you have labview 5.1 or 6, you can find useful VI's in the Sound and Graphics pallette. If you have 5.0, I think you can get the VI's from the Developer Zone site.
(2,873 Views)
I've used the "audio in" to determine a fan's RPM, using a microphone. The problem I see with your application idea is the slow sample rate required. I believe choices are 11K, 22K or 44.1K samples per second for the audio input drivers - at least the version I've used. An example of an ocilloscope using the audio sound card drivers can be found at:
http://www.yelmtel.com/~joej/vis/scsco.zip
Perhaps you can modify this to suit.
Joe Jasniewski
(2,873 Views)
