How do I Delete DAQmx Channels
I am pretty much a novice to LabVIEW, and many of you may see this as a very easy question, but how do i remove DAQmx channels (If this is the correct term, or is it tasks?).
I have been playing about, and seem to have a few redundant channels and wish to remove them. I have been looking for a while now and can't seem to find it anywhere.
(4,948 Views)
Hi Clubber,
open MAX and delete the DAQ tasks where you created them...
(4,937 Views)
Accepted by Clubber
You need to open DaqMX by clicking:
Once DaxMX is open you need to open the channels area:
THen you need to right click on the channel or task that you want to delete and select the delete function.
Tim
GHSP
(4,927 Views)
Thats great, thanks for your time tim and GerdW.
Cheers,
Oli
(4,920 Views)
Impressive, comprehensive responses from Tim and GerdW. Good work guys!
Oli, here is a useful link I recommend to any new-comers to the DAQmx platform.
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Hope your enjoying your first experience of LabVIEW!
Best wishes,
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(4,879 Views)
Thanks Rich R, any advice is greatly accepted.
LabVIEW is great software, and I'm enjoying using it. Just finding my feet and finding what sort of functions are availble and how to incorporate them.
Thanks again,
Oli
(4,872 Views)
