How do I access a hidden method?
I have some custom active x classes which contain hidden methods, how can I get access to them in labVIEW?
(3,096 Views)
LabVIEW doesn�t allow direct access to hidden methods ActiveX methods. However, if you use a text based programming language to create a DLL that calls the hidden property, LabVIEW can then call that DLL using a Call Library Node. This will allow you to access your hidden ActiveX methods. There is also an ActiveX Tutorial in the DevZone. Have a great day.
Danny G.
(3,096 Views)
