activex hidden methods
How can I see hidden methods in labview?
My E-mail: harminder.singh@adept.com
(2,813 Views)
LabVIEW doesn�t allow direct access to hidden methods ActiveX methods. However, if you use a text based programming language to create a DLL that calls the hidden property, LabVIEW can then call that DLL using a Call Library Node. This will allow you to access your hidden ActiveX methods. There is also an ActiveX Tutorial in the DevZone. Have a great day.
Danny G.
(2,813 Views)
