How do I acquire on a second analog channel while waiting indefinitely for an external gate on another?
I would like to repitively acquire every two seconds on one analog DAQ channel (ch5) and simultaneously acquire on a second analog (ch7) channel that hangs indefinitely for an external trigger.  Is there a way to do this?
I'm currently running the acquisitions from two different VI's.
I currently get the following error:
Error -50103 occurred at DAQmx Start Task.vi:5
Possible reason(s):
NI Platform Services:  The specified resource is reserved. The operation could not be completed as specified.
Task Name: _unnamedTask<84>
PCI-6014
LabVIEW 2011
(2,901 Views)
No, you cannot do that with a single device. Both channels have to be in the same, single task.
(2,881 Views)
