How do I adjust the gain on an SI3170 camera thru IMAQdx?
I am trying to adjust the gain/brightness on an SI3170 camera (GIGe Vision) thru IMAQdx and I get "Unknown GIGe Vision error" when using the Write Register VI to change the gain. The camera is hooked up through a Pleora interface card, could that be causing the interference?
(2,613 Views)
study here and here.
Post if still you are facing problems.
(2,595 Views)
