How do I build an executable w/o installing the runtime engine in the OS?
Hello everyone
I have developped an application with LabView 8.01 and build an executable for a customer, this works great, if I have administrator rights. But my customer don't have full administrator rights and they are not able to install the software (Runtime Engine). In LabView 6.0.1, to solve this problem we added the lvrt.dll and some support files directly to the application builder as support files and it worked without to install the runtime engine in the operating system.
How can this be done in LabView 8.0.1 and which files are needed?
I am thankfull for any advice.
(2,959 Views)
hi,
you always need admin rights to install software.
I think it's not possible in labVIEW 8.01 to install the runtime without admin rights.
The costumer only has to  the runtime one time, so he should try to contact his system administrator.
I've found no workaround for it.
Best regards.
Christoph Strasser
AE/NIG
(2,921 Views)
