While loop with TCP listen
Hello
I'm trying to do the LabView VI with the functionnality I will describe with a pseudo-coding language:
function sendCommands( String address, String commands ) {
    Socket sock = connect( address, 23 )    // 23 is Telnet
    String[] commandsArray = commands.split( "\n" )
    String responses = ""
    for( i = 0 ; i<commandsArray.length ; i++ ) {
        send( sock, commandsArray[i] )
        String currentAnswer = receive( sock )
        responses = responses + currentAnswer
    return responses
I've been able of creating the socket, sending one command and receiving the response, on the other hand I don't understand how to do the following:
  1. How do I split a string?
  2. How do I send each piece of the string one by one?
  3. How to I concatenate two strings, based on the result of the previous concatenation?
Attached the current version of my work. Comments are in french, I can translate if needed Smiley Wink
Thank you
Message Edited by alitokmen on 05-03-2007 08:57 AM
S. Ali Tokmen
http://ali.tokmen.com
(3,008 Views)
I'll try to answer the best I can :
1 : To split a string : There is a VI named "search/ split string" ... (about 10 sec)
2 : either you use a flat sequence, and you send a string in each step, or you create an array with your string, and you send each elements in a for loop...
3 : To concatenante a string, just use the VI named "concatenante strings...
Hope this helped
Regards
Richard Keromen
(2,982 Views)
Hello
Thank you for your message: it has been very helpful for me. I've therefore done a new version of the VI.
I'm also attaching it, just in case someone else needs it.
Comments are still in french 🙂
S. Ali Tokmen
(2,967 Views)
