Currently, I'm using 6035E to measure the angular position of servo motor.
I'm able to read the counts from Channel A and Channel B.
From the technical note which I downloaded from this website, I understand that the Ch A and Ch B should be connected to pin 37(PFI8/CTR0 SRC) and pin 16(P0.6) of I/O connector, respectively.
However, it doesn't indicate any solution of capturing the Z-index pulse.
I'm wondering whether I can read the pulse by connecting to pin 3 (PFI9/CTR0 GATE).
In fact, I have tried it out and it worked. I can see the counter is counting from the MAX.
The problem is I don't know which VI I suppose to use.
I don't know how to program it in LabVIEW.
If this is not the right, what are the alternatives?
Please enlighten me. Thanks.
IANES
